Old September 21st, 2008, 07:20 PM   #1
shawn3806's Avatar
Default Viper winch issues.
Today I had all 50 feet of my winch line ran out, when I started the pull everything was going fine untill i had about 30 feet or so of line still ran out.* When it reached that point it just sorta died and wouldnt pull anymore.* Does this mean I burnt the thing up?* Because I have no idea, it has never done this before.* Also I snapped my Amsteel Blue winch line, can this stuff be spliced back together or do I need to buy a new line?
Cheers.
3000Lb Viper Winch.
Highlifter Radiator.
Highlifter Springs.
ASR X Series Tierods.
Rox Risers Solex Handlebar.
Drat Fab Lowering Kit.
VFJ Stage 3 Goodness.
EHS Airbox Lid.
Maroon Primary Spring.
</span></span></span>
shawn3806 is offline
Old September 21st, 2008, 07:28 PM   #2
BassMaster's Avatar
Default Re: Viper winch issues.
I snapped mine too, spliced it together and it snapped again in a different spot.
You probably burned it up, take it apart and try to clean it out, it may just have stuff in it.
08 Brute Force 750i
BassMaster is offline
Old September 21st, 2008, 07:35 PM   #3
shawn3806's Avatar
How did you splice it back together?* I'll try tinkering with it tomorrow if I can't fix it I'll send it back to viper It's still under warranty.
3000Lb Viper Winch.
Highlifter Springs.
EHS Airbox Lid.
Old September 21st, 2008, 07:58 PM   #4
BassMaster's Avatar
I let my uncle do it, im not exactly sure how he did it though.
08 Brute Force 750i
Old September 21st, 2008, 08:11 PM   #5
shawn3806's Avatar
10-4
3000Lb Viper Winch.
Highlifter Springs.
EHS Airbox Lid.
Old September 28th, 2008, 07:30 PM   #6
i snapped mine the other day too and it was actually the first time i used it,* first winch out with my new viper max 4500,* was not impressed with the amsteel cable,* ive seen it snap on buddies quads a couple of times.* the* cable warn sells that is grey seems to be the stuff to use i havnt seen it break yet.
05 Brute 750: 11:5:1 JE PISTONS, WEBB CAMS, FULL MUZZY, VFJ STAGE 3 Clutch, 2" LIFT, COPPERHEAD, CENTRE SNORKLES, K&N, DYNO JET and DYNO TUNED. 2009 SUNBEAM RED PLASTICS. 28" ZILLAS, STAINLESS STEEL BRAKE LINES
BRICKLAYER is offline
Old September 28th, 2008, 08:36 PM   #7
What about the synethic ropes for the winches? I ordered mine with the red 10,000 lb. test rope on it and have used it about 10 times with out the first problem yet? Mostly pulling out Honda's, Polaris and Suzuki's. But still had it in a hell-a-bind a few times. Does someone know somthing I don't about these? Seems like a good alternative to the steel wound cables. I broke a couple on my jeep several years ago but it was usually due to something I did like a kink or got it in a bind at a bad angle etc...
Slumlord is online now
Viper winch contactor mount........ Greg G Brute Chassis & Electrical 13 June 25th, 2009 04:02 PM
Viper Max installation Lupine750 Brute Chassis & Electrical 16 March 12th, 2009 10:03 PM
Viper Max winch questions Lupine750 Brute Chassis & Electrical 9 February 24th, 2009 11:49 AM
Viper winch max2500 05-BF-750 Brute Chassis & Electrical 8 March 28th, 2008 09:32 AM
Viper jakedogg Brute Tire & Wheel Combos 2 August 27th, 2007 06:50 PM
