Forum Members: 4,741
August 10th, 2008, 11:23 PM
warn 2500
Has anybody that has a warn winch have had a problem with it not goin out when you press out.
When I press out it just clicks at the selenoid.Could it be the selenoid? help needed.thnks
08' BRUTEFORCE 750i EFI
30" MUDZILLAS,14" ITP SS212'S,WARN 2500,CUSTOM SNORKELS,2" LIFT ,HIGHLIFTER SPRINGS,HMF OPTIMIZER,HIGHLIFTER CLUTCH KIT,HIGHLIFTER BELT,FULL HMF EXHAUST
August 11th, 2008, 12:02 AM
Re: warn 2500
My old Warn A2500 did that.* It was a bad contactor.* Warn covered it under warranty, as winch was under a year old.* You can verify the problem by swapping the wires on the winch.* If it then goes out, but not in, you will know it is a bad contactor.* Good luck with it.
August 11th, 2008, 01:00 PM
Re: warn 2500
which wires?the blue and yellow?
August 11th, 2008, 02:14 PM
Re: warn 2500
I don't remember the colors.* Just the two wires that attach to the winch itself.* Reverse them and see what happens.* If it goes out, and not in (reverse of what is happening now), you will know it is a bad contactor.
August 18th, 2008, 10:22 PM
Re: warn 2500
yes the yellow and blue wires
August 19th, 2008, 02:00 AM
Re: warn 2500
I changed them and it didnt do anything.i changed them on the contactor and the winch and still nothing.any other advice?
August 19th, 2008, 10:10 AM
Re: warn 2500
The only other thing I can recommend is to find a buddy with a working warn winch and see if he will let you borrow his contactor.* Then you can at least be 100% sure if that is the problem, or not.
warn 3.0rt
Redbeard |
Brute Chassis & Electrical |
1 |
March 5th, 2008 10:51 PM |
warn contactor on the new warn winches
Mudcon |
8 |
October 30th, 2007 06:29 PM |
Warn at the greatest...
flashpoint |
1 |
October 22nd, 2007 08:12 PM |
Warn Winch
whatwasithinkin |
3 |
October 5th, 2007 04:31 PM |
Warn warranty??
flashpoint |
8 |
September 12th, 2007 02:40 PM |
